OctaneRender™ for Blender 4.00 - 16.3 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
  • Update to 4.00 Stable SDK
  • Support clay mode
  • Support to show octane device settings
FIXES SINCE LAST RELEASE
  • Only show AI strength light under direct lighting kernel
  • Attempts to fix probabilistic black frame issue
  • Log environment object information for hunting probabilistic render issue(run blender with debug mode from command line "./blender -d" to enable it)
This version matches OctaneRender Standalone 4.00. To learn more about the new features and improvements of OctaneRender 4, please check out our blog post.
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.3 (2.79)
Octane Server - 16.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.3 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v16.3 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v16.3 OSX ZIP
