daylight animation
Houdini Integrated Plugin
nKo
Hi, I can't set any keyframe in the daylight system. How can I animate it ? any tricks ?
thanks
coilbook
nKo wrote:Hi, I can't set any keyframe in the daylight system. How can I animate it ? any tricks ?
thanks
in max I just move the sun around to record the animation. Make sure use dummy direction is checked.
juanjgon
In Houdini all the parameters can be animated without problems. For example, you can use ALT+Right click over the parameter name to set a keyframe for the current frame, and so on. Check the Houdini animation basics docs: http://www.sidefx.com/docs/houdini/anim/basics.html
nKo
That exactly what I did. And it work indeed, but I don't know why, sometimes It does'nt want to set my key. I'll try to investigate and notice you if I can reproduce it.
Thank anyway.
nKo
Return to “Houdini”
