4 gpu build advice / review
core.pan
Hello guys. Long time octane user here, decided to get further and build my own 4GPU setup. Been looking this trough a lot and I think everything is compatible and logical, but if by any chance you see something I missed it would be amazing if you could let me know :) Also if you feel interested by this I could post photos of the build, it should be pretty beautiful :) Nice day to you .
Intel - Core i7-7800X 3.5 GHz 6-Core Processor
be quiet! - Dark Rock pro 4 cooler
Asus - WS X299 SAGE Motherboard
Kingston - FURY 64 GB (4 x 16 GB) DDR4-2400 Memory
MSI GeForce GTX 1080 Ti AERO 11G OC x4
be quiet! - Dark Base Pro 900 ATX Full Tower Case
Corsair RM1000W
Samsung - 860 Evo 500 GB 2.5" Solid State Drive x2
FrankPooleFloating
Just curious, but what info were you basing your choice of a 1000W PSU on? Was that just a guess or did someone in Octane forums suggest 1000W for four GPUs somewhere?
Below is copied from this thread: viewtopic.php?f=11&t=64984&p=330218
If you are in Europe, Asia, etc, get a Super Flower Leadex Titanium 1600W.. if you are in North America, get the EVGA SuperNOVA 1600 T2 80+ TITANIUM, which is the same (rebranded OEM for EVGA). Even if 1600W is waaay more juice than four 1080Ti GPUs are asking for, this is definitely the PSU you want. And hey, if you are only using around 1000W-1200W at full load, maybe the fan would never even spin up on this bad-boy...
core.pan
Thanks, I was under the impression that 1000w would be powerful enough, but after a bit of research you're right, gonna switch for 1600w. Thanks :)
glimpse
Good day Guys,
actually full system usage with older OctaneRender version would be around 1000W, but new version utilize GPus a bit better and thus power usage rise a bit.
7GPU (1080ti + six core) system with overclock on both CPU and GPUs sips around 1400W from the wall, so technically 1600W unit could easily handle bigger system than 4GPUs without a glitch.
However, if You look at efficiency curve (that You can find on official pages) of most PSUs, the You'll notice that those are usually most efficient at around 50%. Forcing PSU to go on the edge not only shortens life span and degrade it internal component, but also might effect ripple suppression and other thing negatively, so technically speaking it's worth to unit twice as big as You "actually need".
hope this helps.
FrankPooleFloating
Hey, thanks Tom! I knew it was something along those lines, but you articulated much better than myself, and with greater authority. ;)
Amzn has the SuperNOVA 1600 T2 right now for an astonishingly low $245!! :shock: And the 1600 P2 for $179!!! :shock: :shock:
