Errors in log
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
J.C
I created a simple scene one object and a material. The log shows some bugs like this.
Tried to access pin via an invalid ID P_UNKNOWN (0)
Tried to access null node pin
Can't read bool from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x104857d08)
Tried to access pin via an invalid ID P_AI_LIGHT_STRENGTH (385)
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x104857d08)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x104857d08)
Tried to access pin via an invalid ID P_SUN_DIR (231)
Node type 6 is either unknown, a linker or incompatible to static pin 'rotation' (P_ROTATION, type PT_TEXTURE) of node 'test' (NT_MAT_GLOSSY, 0x7fb4d4706d70)
Tried to access pin via an invalid ID P_RENDER_PASS_REFRACTION (185)
We can't evaluate items of a different version (version 0)!
console errors.blend
(837.87 KiB) Downloaded 187 times
System – Windows 11
J.C
Another one when transforming a bitmap texture with Full Transform node.
Node type 6 is either unknown, a linker or incompatible to static pin 'rotation' (P_ROTATION, type PT_TEXTURE) of node 'metal' (NT_MAT_METAL, 0x7fb4caa048c0)
System – Windows 11
Return to “Bug Reports”
