Octane Sky Background\Backplate [3.08.5 - 12.58] [Solved]
blackshore
Hello folks.
I have set Octane SunSky to Daylight environment and Daylight enviroment>Daylight type to Daylight system.
I have enabled visible environment and set octanesky as visible environment.
The objects in scene are affected as with the environment settings but the background is black.
octane sky
octane sky
How do I enable environment for background?
calus
blackshore wrote:Hello folks.
Maybe you just need either to remove/disable the OctaneRenderLayer1, or disable "alpha" in your Kernel.
Pascal ANDRE
blackshore
calus wrote:Maybe you just need either to remove/disable the OctaneRenderLayer1
Yup this was the solution worked! Thanks!
Return to “Autodesk Maya”
