OctaneRender™ for Blender 3.08.5 - 15.3.4 [STABLE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgrade to 3.08.5
  • Add option to support untonemapped image rendering with camera imager ("Render" - "Render" - "Prefer tonemap if applicable")
  • Add option ("User Preference" - "Add-ons" - "OctaneRender Engine" - "Generate Default UVs") to generate default UV Map when creating preset primitives
  • Force to switch to solid mode when clicking "Stop Render and Empty GPU"
  • Support "texture type" and "sample per pixel" in baking texture node
  • Add button to reload image for all image texture nodes
  • Rename float tex to grayscale tex to make it better understanding
FIXES SINCE LAST RELEASE
  • Fix particle texture setting missing
  • Fix camera border mode render issue
  • Fix direction issue in toon light
  • Fix update failure when deleting toon lights
  • Fhange the out tex type from shader to vector for float value node and int value node
  • Fix default power value from 0.9 to 1 for all image texture nodes
  • Fix maximum value error of parallel samples and max tile samples
  • Fix transform node render failure in nodegraph
  • Fix image sequence issue
You can read about new features of OctaneRender™ 3.08.5 here:
viewtopic.php?f=24&t=69127
1. OctaneRender™ Server
Windows
Blender Octane Edition - 15.3.4 (2.79)
Octane Server - 15.3.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v15.3.4 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.3.4 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.3.4 OSX ZIP
