OctaneRender™ for Blender 4.0 RC7 - 16.2.8 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Add an option to control whether to enable node graph upload optimization("User Preference-OctaneRender Engine-Node Graph Upload Optimization")(disable as default)
  • Support drag and drop to create octane image texture
FIXES SINCE LAST RELEASE
  • Fix probabilistic render failure when using node graph upload optimization
  • Fix autofocus active state bug
  • Fix viewport border render update delay
You can read about new features of OctaneRender™ 4.0 RC7 here:
viewtopic.php?f=33&t=69243
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.2.8 (2.79)
Octane Server - 16.2.8
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.2.8 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v16.2.8 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v16.2.8 OSX ZIP
