Disp + Norm shading problem
remon_v
I get a problem when I use a normal map and a displacement map at the same time.
I am using an older version: Modo801_3_3_3_112, because I'm still on Modo 701
remon_v
Win7 Pro x64, Phenon II 940, 8 GB, Geforce 470 - Modo, Zbrush
Hi - this is resolved in more recent versions of Octane, so you will need to upgrade to resolve this issue.
remon_v
Thanks for the answer, I noticed the latest stand-alone version doesn't have this problem.
I would prefer to work in Modo and upgrading it is too expensive at the moment.
I tried a work aroung with a mix material and attatch the displacement in the mix node, but that doesn't work for me either.
Is there a work around for this?
remon_v
You cannot use bump maps and displacement maps together in the version you are using. I'm sorry, but you will need to upgrade to resolve this.
Return to “Foundry Modo”
