1.1.2.1352
Moderator: ChrisHekman
Xhed
Changes since 1.1.1.1341
Features
  • Upgraded to Octane 4.00 RC 7.
Fixes
  • Force scene update before ORBX export.
  • Fixed issue with SkinnedMeshRenderers.
  • Fixed issue when exporting render passes to a layered EXR file.
  • Fixed issues with Recorder exports.
- Rick
fleity
in 1352 I still have this issue
NullReferenceException: Object reference not set to an instance of an object
Octane.MeshSkinned.GetActualRoot (UnityEngine.SkinnedMeshRenderer meshRenderer)
Octane.MeshSkinned.HasChanged (UnityEngine.SkinnedMeshRenderer smr)
Octane.MeshSkinned.OnUpdate (UnityEngine.SkinnedMeshRenderer skinnedMeshRenderer, Octane.MeshSkinned meshSkinned)
OctaneUnity.ObjectLink`2[TU,TO].Update (System.Collections.Generic.HashSet`1 unityItems, Boolean fixMissingComponents)
OctaneUnity.Scene.UpdateScene (Boolean blockRender, Boolean force)
OctaneUnity.PluginController.UpdateInternal ()
OctaneUnity.UpperManagement.Update ()
UnityEditor.EditorApplication.Internal_CallUpdateFunctions () (at C:/buildslave/unity/build/Editor/Mono/EditorApplication.cs:191)
to reproduce:
new scene, create pbr render target, create cube, load octane,
add any deformed mesh from an fbx
press render, the error occurs for every sample
the scene / unity instance is corrupted afterwards and will keep erroring while rendering until unity is restarted, just removing the skinned mesh renderer geo is not enough
GTX 960M (multi gpu with intel integrated graphics) Unity 2018.2.15f1
I am kind of dependent on the file I am trying to render... help, please? if I can provide any other info I'd gladly do that.
ChrisHekman
fleity wrote:in 1352 I still have this issue
to reproduce:
Could you PM me your fbx file?
fleity
thx Chris, I'll send you a minimal version of the unity project including the fbx file
if anyone else wants to have a look at it:
unity project zipped: open scene GH010088d (in Assets Folder)
https://www.dropbox.com/s/jqpszflbm7j2m ... r.zip?dl=0
the fbx file in question (in the project zip it is included and set up with materials, animations curves are loaded from another file)
https://www.dropbox.com/s/779ub2ljt1icu ... t.fbx?dl=0
I can confirm that it is a mesh / fbx issue. A fresh cube with 2 joints exported from maya works flawlessly. I will try to rebuild the mesh that causes the issues and figure out what exactly it is but in any case an uncaught exception like that is probably not what should appear.
well and obviously the previous version 1.1.1.1341 works too
athosrojas
Octane progressive lightmapper is working now?
ChrisHekman
fleity wrote:thx Chris, I'll send you a minimal version of the unity project including the fbx file
I have tested in the latest version (1362) and the GH scene works in that version. We did fix a bug related to the skinned mesh renderers, so it might have been fixed.
Could you confirm?
ChrisHekman
athosrojas wrote:Octane progressive lightmapper is working now?
It now creates an gameobject that stores the resulting lightmap data.
fleity
Could you confirm?
Yes version 1362 fixes the skinned mesh renderer null reference exception issue
Return to “Unity”
