OctaneRender™ for Blender 4.0 RC7 - 16.2.7 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgrade to v4 RC7
  • Support OctaneRender system for each blender built-in layer
  • Add option "Render Layers-Layer-Use Octane Render Layers"
  • Rename "Render Layers-Octane render layers" to "Render Layers-Octane render layers(Global)". You can use it in preview mode or overwrite render layer settings
  • Add option to disable object layer properties when exporting("Export Dialog-Export with object layers")
  • Support show octane log
FIXES SINCE LAST RELEASE
  • Optimize performance
  • Do not upload nodes that are not used
You can read about new features of OctaneRender™ 4.0 RC7 here:
viewtopic.php?f=33&t=69243
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.2.7 (2.79)
Octane Server - 16.2.7
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.2.7 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v16.2.7 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v16.2.7 OSX ZIP
[/list]
