Safe Frame not working
Bendbox
Hi Paul,
I've just noticed another issue . . . but I don't know if this is Rhino or Octane -- the Safe Frame is not working properly. Octane doesn't seem to render according to the Safe Frame. I do have "Sync Octane FOV to Rhino" checked. Anyone else experiencing this too?
Ryan
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
Hi Ryan. Hopefully this version will fix the safe frame problem.
https://render.otoy.com/customerdownloa ... _5_101.rhi
Bendbox
Hi Paul,
Is this one different than the 101 you posted yesterday? If not, then unfortunately, it's not fixing the safe frame issue.
I do have "Sync Octane FOV to Rhino" checked by the way. Was there some other change in Rhino6 that i need to also have selected other than the options in the Safe Frame window?
Ryan
Ryan - the build above is different to the other build (it is more recent).
Bendbox
Hi Paul,
I downloaded and installed the version in your link above -- it is the same number as the previous build btw, just thought I'd mention it in case the wrong version was at that link. Unfortunately, Safe Frame is still not working correctly.
Thanks for your help on this,
Ryan
Hi Ryan
Can you try this version please (version number unchanged).
Bendbox
Safe Frame is now fixed in this latest build!! Thank you Paul!
Ryan
Return to “Rhinoceros 3D”
