Version 4 not releasing licenses?
sjogren
Hi.
I have some problems with the version 4 of the plugin, my licenses remains locked and are not being released even if I close Modo!
If I start and shut down the standalone, then that license is released but the Modo plugin license is never released?
/Niklas
Windows 10 (64-bit) | GeForce GTX 1070 & 970 (416.34) | i7 6850K | 32 GB System Memory
Modo 12.1v2 | Plugin Version: latest beta 4
Hi Niklas
I suspect this is possibly due to a Modo10.1v2 issue (fixed in the next version of Modo) where Modo is not exiting correctly. If you can back to a previous version of Modo if may resolve this issue.
This issue turned out to be a plugin bug. I have put through the Octane 3.08.5 build fix at viewtopic.php?f=34&t=55078&start=610. The Octane 4 build fix will be in the next release (in the next week).
sjogren
That's great news, thanks...
/Niklas
teknofreek
I'll post in the general octane 4 modo topic as well, but this is happening to me atm.
I have released the Octane standalone license for the pending update to Octane 4 release and my account shows that the standalone license is deactivated, but the plugin is still showing active on my machine.
I was running a version of Octane 3.08.1 standalone and its plugin and Octane 4 RC7 and the associated plugin under Modo 12.2v1.
I have restarted the PC and relogged into my account and it still shows active.
Do I have to use an unlock it, or should I just upgrade to Octane v4. It is only due to the warning to deactivate prior to undating an existing v3 license that I post this.
Win 10 Pro 64bit, AMD 1950X 3.6 Ghz, Gigabyte AorusG7 X399 MB, 1x GTX 680 1x GTX 770 mainboard, 4x GTX660ti external, 32 GB onboard mem
Nvidia drivers 388.59
Return to “Foundry Modo”
