'Refreshing Octane Geometry' is killing me.
Greg
I have a pretty complex CAD file (a few thousand mesh items, instances and replicators). It's a 180 frame animation with just the camera and a couple of locators with parented geometry moving. Frame 1 (or a still frame) takes about 1 minute of 'Loading Scene into Octane' and 1 minute of rendering. Nice. Well, on frame 2 (and all the others) MODO takes upwards to 10 minutes of 'Refreshing Octane Geometry'.
One the Mesh Items 'Live Geometry Update' is not checked. 'Reload mesh each frame when animating is not checked'
I remember a 'Load All frames into Octane' option at some point but that doesn't seem to exist anymore.
The 'Don't reload mesh objects' is greyed out in the 'Octane Kernal/Animation' prefs. I don't know if this would help if I could figure out how to turn it on since I'm afraid it won't pickup the animation.....
Paul, any help? What's going on? Seems like once the geometry is loaded into Octane and there's just simple transforms or camera movement you shouldn't have to load the whole scene back in...and also why is 'Refreshing Octane Geometry' literally 10x slower than the initial 'Loading scene into Octane'? Going to try and save this out as an animation and render in stand alone. I need this to figure this out.
-G
CEO Sabertooth Productions
Co-Founder Pixel Fondue
Greg
Btw - using octane.saveAnimation and saving out an .ocs and rendering in stand-alone is not problem (so I'm not screwed here)...but it is weird and buggy with the whole 'refreshing octane geometry' taking 10 minutes when the initial scene load is only 1 min.
Hi Greg - are you able to send the scene to me please?
Greg
Hi Paul - can you send me an email to greg at sabpro dot com. I'll reply with a link to the scene.
lightvu
Hi did you ever find a solution to this problem? I an having something identical happening over here.
Please send any scenes exhibiting this issue to paul at physicalc-software dot com.
The latest version of the plugin substantially increases the speed with which scenes with large numbers of live meshes load. So if you have performance issue with a particular scene, pls try the latest plugin version.
OlaHaldor
Latest, meaning 2018 which now is subscription instead of a straight out purchase?
Modo & LightWave 3D | Win 10 x64 | RTX 2080 Ti | Threadripper 2920x | 128GB
I don't understand this question, sorry.
OlaHaldor
Do you refer to Octane 2018, or both 2018 and the latest build of Octane 4?
Return to “Foundry Modo”
