OctaneRender™ for Blender 4.0 RC6 - 16.2.6 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgrade to 4.0 RC6
  • Support render layer ids from blender built-in layer system
  • Object with "Data"-"Octane properties"-"Layer number" as 0 will use layer id from blender built-in layer system
  • Add option "User Preference"-"Add-ons"-"OctaneRender Engine"-"Use Blender Built-in Render Layer" to choose use default layer system(octane or blender built-in)
  • It will not affect layer ids settings before. Just an optional choice
  • Support %i pattern for image tile texture
  • Support "texture type" and "sample per pixel" in baking texture node
  • Force to switch to solid mode when clicking "Stop Render and Empty GPU"
  • Rename float tex to grayscale tex to make it better understanding
  • Add button to reload image for all image texture nodes
  • Remove cudnn64_7.dll from setup packages
FIXES SINCE LAST RELEASE
  • Fix transform node render failure in nodegraph
  • Fix image sequence issue
  • Fix image tile crash on osx
  • Change the out tex type from shader to vector for float value node and int value node
  • Fix default power value from 0.9 to 1 for all image texture nodes
  • Fix maximum value error of parallel samples and max tile samples
You can read about new features of OctaneRender™ 4.0 RC6 here:
viewtopic.php?f=33&t=69070
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.2.6 (2.79)
Octane Server - 16.2.6
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.2.6 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v16.2.6 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v16.2.6 OSX ZIP
