Overscan + Limited Region
LichtUndSchatten
LW 2015.3
Octane Plugin : 4.00 0.15
Octane API buid: 4.00 RC5
Octane DLL version: 4000015
I´ve a scene with used Overscan Feature in the LW Camera Settings.
If i render the whole image with Octane it works like it should do.
But if i use the LW Limited Region it is restricted in width an height and only renders areas like
without overscan. So thats very annoying becaus there is no possibility to fix certain areas
in the overscan areas without rendering the whole image again :(.
Is there a way to fix this issue?
The only other way would be if i could get a chance to "bake" the overscan camera
as new camera without overscan.
I´ve found this script
"https://forums.newtek.com/showthread.php?141133-Clone-Overscan-Camera-single-shot-Generic-script-for-Layout-11-5" .
Is someone able to adapt this script here so that i can put in width and height of overscan in pixels and a new camera will be created? The script is only functional with width input.
Thanks for ypur help.
Return to “Lightwave 3D”
