Undo/Redo
Moderator: ChrisHekman
Sergey91
Hey guys!
Undo/Redo function doesn't work in Octane Plugin for Unity. This complicates work a lot. Could you fix it please?
Xhed
Hi Sergey,
is there a location where undo/redo doesn't work? We've added support for it, but it seems that we didn't do that everywhere properly.
- Rick
Sergey91
There is no particular location where it doesn't work, It doesn't work in general in Octane plugin for Unity. For example if I accidentally delete any node, I can't undo this action.
It is not even active (see attachments)
I'd appreciate if you could double-check things here.
Xhed
Your attachment isn't showing for me, it redirects me to Imgur's 404 page.
Where are you deleting a node? Are you referring to the Octane interface?
- Rick
Sergey91
Yes, exactly. As we're talking about Octane, I meant any action in Octane UI - delete node, make any adjustments to the materials inside Octane plugin, literally anything that is done through Octane's UI. Does it make more sense now?
Here's the missed image https://imgur.com/S2zaZ3Y
manusd
I`ve got the same problem. Any solution to this?
Return to “Unity”
