OctaneRender™ for Blender 4.0 RC5 - 16.2.5 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgrade to 4.0 RC5
  • Add "Light Linking invert" in AI light
  • Add option to support untonemapped image rendering with camera imager ("Render" - "Render" - "Prefer tonemap if applicable")
  • Add option ("User Preference" - "Add-ons" - "OctaneRender Engine" - "Generate Default UVs") to generate default UV Map when creating preset primitives
  • Optimize environment texture upload (do not upload unused textures)
  • Add option ("Data" - "Octane properties" - "Force load vertex normals") to fix issues in data transfer modifier
  • Adjust default and maximum values of parallel samples and max tile samples
FIXES SINCE LAST RELEASE
  • Fix particle texture setting missing
  • Fix random environment updates failures
  • Fix camera border mode render issue
  • Fix default power value from 0.9 to 1
  • Fix order of "Rotation" attribute in glossy material
  • Fix direction issue in toon light
  • Fix update failure when deleting toon lights
  • About the UV Maps issue, we have added an option to generate UV Maps automatically:
    • Add option ("User Preference" - "Add-ons" - "OctaneRender Engine" - "Generate Default UVs") to generate default UV Map when creating preset primitives.
    • If the users want to use startup file to test LiveDB materials, they need to modify the startup file (add a UV Map to the cube) then save it manually.
You can read about new features of OctaneRender™ 4.0 XB5 here:
viewtopic.php?f=33&t=68871
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.2.5 (2.79)
Octane Server - 16.2.5
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.2.5 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v16.2.5 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v16.2.5 OSX ZIP
