Hi, is loading mesh speed in 3d max taboo ?
Each time I ask I don't have any answer. Is there a solution, a workaround, is it a high priority, do we need to leave 3dsmax and switch to another software ?
It would be good to know....
Loading mesh speed in 3d max taboo ?
- paride4331
Hi HHbomb,
Octane V4 is not stable, not for production. SDK developers are working and Octane plugin developers have to optimize Octane SDK for each Octane plugin and fixe every issue while Octane SDK is still under development. When users find issues and report it is a great help, but please, never forget Octane 3.08x is only stable version at the moment.
Regards
Paride
Regards
Paride
For some scenes, loading meshes is longer than rendering time...
It seems to be a high priority, hope someone at Otoy is consciously aware of this.
- paride4331
Hi did you try that?HHbomb wrote:For some scenes, loading meshes is longer than rendering time...
viewtopic.php?f=80&t=68395&p=347944#p347944
Regards
Paride
It is by default....
- paride4331
Hi HHbomb,
render faster than loading meshes it could happen, sometimes this can be normal.
Said that. I tested RC5 now: 32 million poligony (no instances), time loading meshes 53 seconds.
i7 32gb
What about your issue?
Regards
Paride
i7 32gb
Regards
Paride
- SergKlyosov
Hi Paride,paride4331 wrote:Hi did you try that?HHbomb wrote:For some scenes, loading meshes is longer than rendering time...
Regards
Paride
I'm familiar with this setting, but can you please explain in details what is the difference between 3 options?
I know only one thing "None" option will bus loading speed if you have a lot of objects. What exactly do others do?
Cheers
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
Hi Paride, I'm back on this topic
Voxelisation or loading mesh in gpu, I don't know really how it works, but the process isn't multithreaded at the begining, and if it is doable, it could cut by 10 or more loading scene time.
