OSL - Random UV Mapping
kcpr-raffaEl
I'm wondering if there is possibility to randomize texture coordinates?
Maybe using OSL?
roeland
A good starting point is to create an OSL Projection node.
The default looks like this, and implements UV mapping:
shader OslProjection(
    output point uvw = 0)
    uvw = point(u, v, 0);
You can also implement world space linear mapping:
    uvw = P;
To implement something similar as the offset texture of the Turbulence node, add a color input and add it to the UV coordinate. Then add eg. a noise texture to that input:
    color offset = 0,
    float amount = 1 [[float min = 0.01, float max = 10, float sliderexponent = 4]],
    uvw = P + amount * offset;
Roeland
kcpr-raffaEl
Thank you!
I'll be more specific.
I need to randomize RGB Image U and V translation for hundreds of object instances.
Like ceramic tiles with one texture but randomly distributed on each one.
Earlier I did it using Uunwrap, but maybe it's easier to randomize it with OSL?
J.C
What about random texture rotation? Can it be done in OSL too?
System – Windows 11
