Hi Folks,
Is there already a usable release, which works under the R20 of C4D? Have just tried 4.0-RC5 and do not even get a simple cube rendered without C4D crashes. That's really annoying.
When is finally the final, stable 4er version for the C4D plugin out?
Kinds
Cyber-Steve
Octane unusable under R20
I'll not answer if it's a question to folks! Regards!
- Cyber-Steve
Hello aoktar, do not understand your answer (brooding).
O.K., then I put the question to you directly
Thanks in advance.
Kind Regards
Cyber-Steve
Thanks in advance.
Kind Regards
Cyber-Steve
There is not yet a final version of the v4 Octane core, so obviously there can't be a final plugin.Cyber-Steve wrote:When is finally the final, stable 4er version for the C4D plugin out?
If you want stable use v3.08 - 4
C4D 2025 | Win10
What's the problem? Cuda errors with V4-RC5? I can render many of scenes without any problems. You can try different nvidia drivers.
- Cyber-Steve
The problem is thats my C4D crashed if I starting render with the new pluginversion without any error code. To see the reason I should use a crystall globe.
Where I can see the reason code ? I´m an artist and no technician/programmer. Should I use every existing nvidia driver ?
A little help with finding a fault would be very helpful.
Thanx a lot
Steve
Thanx a lot
Steve
Cyber-Steve,
Can you provide some info about your computer / setup?
OS, Video card(s), driver versions etc. Any info will help.
Have you tested Octane standalone, and can you render from there OK?
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
You can read what to do for crashes in release topic. But just drop your bugreport.zip for start.Cyber-Steve wrote:The problem is thats my C4D crashed if I starting render with the new pluginversion without any error code. To see the reason I should use a crystall globe.
Thanx a lot
Steve
