Is it possible to save Beauty pass and Denoise beauty in the batch script? Allowing the amount denoise blend to be applied in post.
Not sure if this is a bug or feature? Should 'save all passes' save both?
Save Beauty pass and Denoise beauty in Batch Script
- teeshiiddo
Asus X99 10G WS | Windows 10.0 | 6x GTX 1080 Ti + 2x 2080Ti | i7-6850K CPU @ 3.60GHz | 32GB RAM
- richardyarlett
Yes agreed. What is up with that ? FOLLOWING.
Wait- What is the problem with how it is?
I have in past run batch-run for Denoised image sequences, and I was able to have the images render correctly as I wanted with the last Denoiser 'amount' that I had set in Camera Imager.
What more do you need, some option to tweak after all the images have been run, like a (1) whole set of 0% denoised, and then a (2) whole set of 100% denoised, and then you could composite-blend those (1 + 2) later on?
Abstrax, you haven't changed the mechanic since the early V4's right? I have found it works fine, but haven't used since last 2 RC's.
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
Plugs: Enterprise
