OctaneRender™ for Blender 3.08.3 - 15.3.1 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Upgrade to 3.08.3
  • Merge updates and fixes in 16.x
  • Support new render pass system
  • Support new scatter conversion with instance ids for duplication/array modifier/particle system
  • Support node graph features
  • Support backward compatibility for mid level displacement
  • Reorganize camera dof panel
FIXES SINCE LAST RELEASE
  • Fix material missing issue in particle system with inactive source objects
  • Fix missing refract channel in render layer node
  • Fix min environment power value issue
  • Fix instance range node id error
  • Fix animation export failure for lamp materials
  • Fix same name issues for linked objects
  • Fix material missing bug in object instances
  • Fix transmission input interface bug
  • Fix camera motion blur issue
You can read about new features of OctaneRender™ 3.08 here:
viewtopic.php?f=33&t=63219
1. OctaneRender™ Server
Windows
Blender Octane Edition - 15.3.1 (2.79)
Octane Server - 15.3.1
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v15.3.1 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.3.1 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.3.1 OSX ZIP
