Octane Rendering Out the Wrong Frame
atmosvere
Hey guys,
Having a slight problem here. I want to render out only one specific frame of a project (24F), but for some reason, it's not getting rendered out (another frame at the beginning is instead). I've switched it from Current Frame to Manual Frame multiple times, but what's in my perspective viewer isn't what's being rendered out. I've also deleted all non-Octane materials from the project to try to get the problem resolved, but it keeps rendering out the wrong frame. It may be important to note that I do have some soft body shapes in the project, but I've never had this happen before so I'm pretty stumped and a little frustrated. Anyone have any ideas?
I'm running the Octane plugin 3.08.2 on Cinema 4D R19 on MacOS 10.13.6 with an GTX 1060 6GB eGPU
please, update to v3.08.3, based on your license type and operating system:
viewtopic.php?f=85&t=68503
if not enough, please share a dropbox or google drive link to the scene via PM with me, thanks.
ciao Beppe
It cannot render wrong frame, because frames are supplied by C4D. But you may have different results due softbody. Did you tested content with standard renderer?
atmosvere
aoktar wrote:It cannot render wrong frame, because frames are supplied by C4D. But you may have different results due softbody. Did you tested content with standard renderer?
When I export using the standard renderer, it's just a black image because I'm using all Octane materials. But it's showing up in the Octane live renderer just fine.
atmosvere
bepeg4d wrote:Hi,
ciao Beppe
Ok will do!
Delete all materials so.
