Nuke 11.2V3 Support
NUKE Integrated Plugin
phileast67
I have an issue within Nuke 11.2v3 , when trying to use Octane Render 3.0.8.036 (last stable build)
"C:\Program Files\Common Files\NUKE\11.0\plugins\OctaneRender.bundle/OctaneRender.dll: The specified procedure could not be found."
Any help appreciated.
Any news on V4 plugin ?
Regards,
Phil
Hi Phil
Foundry have changed the Nuke SDK with release 11.2v3, so the plugin will no longer load. This will be fixed in the next release of the plugin, however in the meantime you will need to revert to an earlier version of Nuke if you wish to use the plugin.
Renbry
hi!
Did/will this be fixed ?
I'm keen to have it as part of our toolkit until Nuke 12 comes around; our maintenance will be renewed then so we're on 11.2v3 until then.
Thanks!
Yes, however you need Nuke 11.3v*. The download is available at viewtopic.php?f=91&t=71073
Renbry
Oh I see.
We're going to have to wait then. Our licenses go up to 11.2v5 so we're getting the "specified procedure could not be found" error when loading the plugin.
I'll check back once we upgrade.
Return to “NUKE”
