OctaneRender™ for Blender 4.0 RC4 - 16.2.4 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgrade to v4.0 RC4
  • Motion blur preview issue
  • Instance range node id error
  • Baking texture issue
  • Support denoise volumes
  • Add passes: denoise emission, denoise volume, denoise volume emission
  • Add dielectric map in universal material
  • Reorganize camera dof panel
FIXES SINCE LAST RELEASE
  • Fix instance range node id error
  • Fix denoise render status text error
  • Fix animation export failure for lamp materials
  • Fix same name issues for linked objects
  • Fix material missing bug in object instances
  • Fix transmission input interface bug
  • Fix camera motion blur issue
  • Fix linux lib missing failure
You can read about new features of OctaneRender™ 4.0 XB4 here:
viewtopic.php?f=33&t=68283
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.2.4 (2.79)
Octane Server - 16.2.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.2.4 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v16.2.4 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v16.2.4 OSX ZIP
