Recorder repeats frames
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
kapitastic
Hi everybody. Recentrly I'm having a problem when recording an animation with the recorder option.
This happens even with a fresh new project, when I record the animation, the recorder repeats all the frames twice, so when you play the image sequence it looks like has been recorded with a diferent frame rate.
here is an example of whats happening: Image
I hope you can help me with this! Last week everything was fine, but today has started to fail!
Thank you.
Xhed
We're looking into the issue. Could you tell me if you're missing frames as well? Is it rendering 1 1 3 3 5 5 or 1 1 2 2 3 3 4 4?
- Rick
kapitastic
Hello, I've found a fast "solution".
I've created a plane and a sphere, this last with rigid body component, so when I start the animation the sphere falls over the plane. Then I put the two meshes away from the camera. It solves the problem.
By the way, it doesnt skips frames, so it goes 1 2 3 4 5 6 7 8, as you can see in the image I posted...
Return to “Octane for Unity”
