Frame-rate issue
spartan00j
Hey Paul,
I'm getting back into animating after taking a break. I animated a scene in poser and exported the animation for Octane stand alone. But in octane stand alone I noticed a Framerate issue. The camera animation itself is fine but the character animation is off.
Octane imports all the frames (which is 1629) and the stand-alone FPS is 24 but the character animation is off. But if I change the standalone FPS to 30, the frames increase to 2037 but the character animation is fine but the camera frame rate is off.
To clarify more, if I open an exported animation in Octane Stand -Alone and go to frame 100 and look back at frame 100 in poser. The animation doesn't match/sync/ Framerate is off.
But thinking about it I set the FPS in the animation panel in poser 30 FPS, (Like I always have). So does the plugin just exports at 24 FPS?
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
Hi. Yes, the plugin assumes the Poser frame rate is 24fps, so I suggest using 24fps.
spartan00j
face_off wrote:Hi. Yes, the plugin assumes the Poser frame rate is 24fps, so I suggest using 24fps.
Paul,
I know this is an old topic but is there any chance can there be a frame rate adjusting to the exporting animation?
I know octane default takes 24 frames per second but you can change that in octane.
But can there be settings added so I can change posers export animation frame rates to 30 frames per second?
Win 11
128GB RAM
RTX 3060 TI
I've had a look at the code. One potential solution is allow users to specify the export FPS in the OctaneDefault.py file. Would that work for you?
spartan00j
face_off wrote:I've had a look at the code. One potential solution is allow users to specify the export FPS in the OctaneDefault.py file. Would that work for you?
Yes
Win 11
128GB RAM
RTX 3060 TI
spartan00j
Yes
ETA on implementation
Win 11
128GB RAM
RTX 3060 TI
2022.1 RC2 has an issue which effects the plugin which is fixed in RC3 - so just waiting on that. Soon hopefully.
I am working on this at the moment - and suspect there is a better solution. You can set the Poser FPS via the Animation Palette - so the plugin could use the FPS set there. Would that also work for you?
spartan00j
yes, that would be best.
Thank you so much!
Win 11
128GB RAM
RTX 3060 TI
Return to “Poser”
