OctaneRender™ for Blender 4.0 RC2 - 16.2.2 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgrade to V4 RC2
  • Support backward compatibility for mid level displacement
  • Support projection in OSL node
  • Support empty tile color in UDIM node
  • Add Planetary Environment type
FIXES SINCE LAST RELEASE
  • Add missing refract channel in render layer node
  • Optimize environment texture update
  • Fix material missing issue in particle system with inactive source objects
  • Remove denoise refraction
  • Environment power can be down to 0
  • Fix the order of UV generation list in UDIM node
  • Fix render layer mode error
  • Fix probabilistic denoise failure
  • Fix ior error in universal material
  • Rename "Specular color" to "Specular" in universal material
  • Rename "Artistic" to "Default" in universal material
You can read about new features of OctaneRender™ 4.0 XB4 here:
viewtopic.php?f=33&t=68283
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.2.2 (2.79)
Octane Server - 16.2.2
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v16.2.2 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v16.2.2 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v16.2.2 OSX ZIP
