can the materials for proxy objects be remembered?
jimho
Dear Paul
It seems the material for proxy will not be saved ,each time after I saved a revit file and close, the materials will be gone, when reopened they becomes light grey colored raw material, I have to reassign all the materials for all the proxies.
is this the normal situation, or there is a way to keep the material?
I tried to save the materials as default but seems not working...
Kindly please let me know what to do, and I am using the version 3.08 octane for revit.
Many Thanks,
Jim
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
Proxy materials should be saved in the .rvt file and re-loaded when the scene is loaded. I will test this is still working in the latest release and get back to you. Sorry for the delay.
This is working correctly with Revit 2018, but not Revit 2019, so I will track down the problem.
Hi Jim. Can you please tell me if this version resolves your problem?
https://render.otoy.com/customerdownloa ... _Win64.exe
jimho
exactly, it is Revit 2019
Cool, I will try it.
Thank you Paul !
Jim
________________________________________________________________________________________________
supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 | titan V+ Gtx1080ti
Return to “Autodesk Revit”
