hi !
i'm pretty impressed by your software render !
i'm fallen here by searchinf cuda render in Google....
i'd like to knwo if Octane can import Poser Pro animations to render them (and export i as a video).
do you have a support list of all animation format than octane can import ?
thank you for you reply.
Best Regards,
Mike
Does Octane can import Poser Pro animation for render it ?
- mib2berlin
Hi, it is no export plugin for poser atm., other plugins support animations export to octane.
It is .dae and .rib support announced for 1.x versions, see features list:
http://www.refractivesoftware.com/features.html
Cheers, mib.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
althou you can export to obj, if I recall correctly poser can export the animation as a series of obj files (obj is a "static" file type and does not contain mesh animation parameters), you would then import the first one in octane, setup material and lights, save the scene, and then throu a simple batch file you could render them all.
- BionicRooster
Poser versions 7 on up can export to RIB.
Win 7 Pro x64, Phenom 9600 Quad Core @ 2.44Ghz, MSI GTX 560 Ti
