Problems with v6 Install
polywog7
Hi!
I'm having a problem installing the current plugin into v6. The installer runs fine with no errors, and the plugin is working fine in v5 and v7. But v6 does not have the plugin installed. I get the "error loading -octanerenderforrhino.rhp" dialog when I open v6 every time i open v6 now. Anyone have any solutions to this?
Thanks!
I would suggest completely uninstalling the RHino6 version of OctaneRender for Rhino plugin. Check Tools->Options->Plugins->OctaneRenderForRhino->Open Containing Folder, and delete that folder. And check for any other OctaneRender For Rhino folders in the parent folder. Then reinstall the plugin. And make sure you are on the latest release of Rhino6.
polywog7
Its strange, since the last couple of updates I've installed, the octane plugin does not show up in the plugins folder. I checked both in rhino and in windows explorer. It shows up fine in v7 and v5 but the only reference that the plugin exists in v6 seems to be that error message upon startup.
This sounds like a Rhino6 issue, so I suggest reporting the problem to McNeel.
Return to “Rhinoceros 3D”
