Render fail
FabioHartmannFernandes
I need some urgent help... i am in a tight schedule here
Could not initialize render, either denoise...
Thank you in advance
Tried to access attribute via invalid ID A_OUT_OF_CORE_TEX_VRAM_LIMIT (308)
can't read int/enum from static pin 'denoiserOriginalBlend' (P_DENOISER_ORIGINAL_BLEND, type PT_FLOAT) of node 'Camera imager' (NT_IMAGER_CAMERA, 00000000F72BB6D0)
CUDA error 2 on device 2: out of memory
-> failed to bind device to current thread
device 2: failed to initialize context
CUDA error 201 on device 2: invalid device context
-> failed to create link
device 2: failed to create OSL compile context:
device 2: failed to compile module 0
Tried to access attribute via invalid ID A_OUT_OF_CORE_GEO_VRAM_LIMIT (307)
can't read int/enum from static pin 'denoiserOriginalBlend' (P_DENOISER_ORIGINAL_BLEND, type PT_FLOAT) of node 'Camera imager' (NT_IMAGER_CAMERA, 00000000F72BB5B0)
can't read int/enum from static pin 'denoiserOriginalBlend' (P_DENOISER_ORIGINAL_BLEND, type PT_FLOAT) of node 'Camera imager' (NT_IMAGER_CAMERA, 00000000F72C8FF0)
Never mind... updated the Nvidia drivers and now it is working
paride4331
Hi FabioHartmannFernandes,
Nvidia drivers version?
Regards
Paride
The last one...
399.07
Regards
Fabio
paride4331
are you using denoising? What about deactivating it?
Regards
Paride
Hi Paride
I was trying to use it, but with the older driver, it was very crashy... with the new driver (399.07) works stable now.
Thx
Fabio
paride4331
thanks for your info.
New 399.07 seem to be stable and work fine.
Regards
Paride
Return to “Autodesk 3Ds Max”
