Automation in Octane Unity
A public forum for discussing and asking questions about the Octane for Unity Alpha
Moderator: ChrisHekman
moot
Hi I would like to script the following in unity + octane:
Perform the following steps on each mesh in a list:
  • - Open the mesh,
    - Load it into the scene (replacing the old one),
    - check the camera frustum to ensure that the bounds of the model are contained nicely within the camera (adjusting the cameras position to frame it nicely).
    - set up a specific octane material configuration for one materials on the mesh.
    - Use unity standard shader on the other material.
    - Load in the textures based off a naming convention in a subfolder with the model name.
    - Render a still use the current scene (lighting/background/setup etc.) to render a still (exporting as png).
    - Once it is done, move on to the next mesh
Is this possible at present? are there any events i can listen for when the rendering is complete etc.
What is the best way to do this with octane, can i script it in play mode, or should i build an editor extension?
Return to “Octane for Unity”
