Save Image Command for batch script
Refracty
Hello Paul,
I am using a script to batch render Rhino views but the problem is that the script restarts the render process again (after each shot). So it re-voxelises even if only the camera position changes.
Is it possible to come up with a script that uses the OCtane - Save image function (same as using the save render - button)?
Thank you
Cheers
Nando
Hi Nando
I think when you change views it will reload the scene, and this would be hard to stop. Instead, you could move the camera in a single view using Grasshopper and render each frame, and the scene will not be reloaded. https://vimeo.com/90721378
Refracty
Thank you Paul for the tip
Return to “Rhinoceros 3D”
