OctaneRender™ for Blender 3.08 - 15.2.6 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions. The download links provided are for Perpetual License Holders.
OctaneRender Studio subscribers can access their software from the "Downloads" section of their Customer Account Page.
  • Support osl textures in texture node graph
FIXES SINCE LAST RELEASE
  • Fix osl load failure when connecting to output node directly
  • Fix freeze issue when adding textures under macOS High Sierra
You can read about new features of OctaneRender™ 3.08 here:
viewtopic.php?f=33&t=63219
1. OctaneRender™ Server
Windows
Blender Octane Edition - 15.2.6 (2.79)
Octane Server - 15.2.6
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v15.2.6 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.2.6 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.2.6 OSX ZIP
