Little cubes appearing on hair
Hi, I have another problem with hair a very bad and almost unusable octane implementation, well, some times appear on the render some little cubes or geometry dancing over the hair, like they are taking the place of some hairs or something, do you know what it could be? some render settings or something?, I am using the lattest octane stable version and maya 2016.
abeoctane wrote:Hi, I have another problem with hair a very bad and almost unusable octane implementation, well, some times appear on the render some little cubes or geometry dancing over the hair, like they are taking the place of some hairs or something, do you know what it could be? some render settings or something?, I am using the lattest octane stable version and maya 2016.
Hello Abeoctane,
Thank you for reporting this.
Not sure if anyone has encountered this. Would you please try exporting as an ORBX animation and check if it has the same issue?
Is it okay to share some screenshots, steps to replicate or sample file? If it's copyrighted then you can PM us.
cheers
Kind Regards
bk3d
bk3d
Hi Bk, It looks like the setting "Clump Width" is the one that maybe is causing the problem, any numer above 0 and the little geometry appear over the hair, but I dont know if it is the only thing causing it.BK wrote:abeoctane wrote:Hi, I have another problem with hair a very bad and almost unusable octane implementation, well, some times appear on the render some little cubes or geometry dancing over the hair, like they are taking the place of some hairs or something, do you know what it could be? some render settings or something?, I am using the lattest octane stable version and maya 2016.
Hello Abeoctane,
cheers
- Attachments
- hair_little_cubes2.PNG (53.67 KiB) Viewed 3481 times
- hair_little_cubes.PNG (266.25 KiB) Viewed 3481 times
Hi Abeoctane,abeoctane wrote:Hi Bk, It looks like the setting "Clump Width" is the one that maybe is causing the problem, any numer above 0 and the little geometry appear over the hair, but I dont know if it is the only thing causing it.BK wrote:abeoctane wrote:Hi, I have another problem with hair a very bad and almost unusable octane implementation, well, some times appear on the render some little cubes or geometry dancing over the hair, like they are taking the place of some hairs or something, do you know what it could be? some render settings or something?, I am using the lattest octane stable version and maya 2016.
Hello Abeoctane,
cheers
Thank you for the steps. Is it possible to share the scene for us to have a look or maybe debug?
Meanwhile, we will try to reproduce and will be in touch soon.
Kind Regards
bk3d
bk3d
Hi BK, unfortunately I cant share with you the scene, but it is a character with a poly mesh made with quads and 2000 nhair follicles.BK wrote:Thank you for the steps. Is it possible to share the scene for us to have a look or maybe debug?
