Hello,
I want to do a slow motion / bullet time effect with a fluid by animating the time scale parameter on the RF scene.
The mesher object has the octane tag with the vertex tags for the motion blur.
Camera also has the tag with motion blur activated.
When rendering the sequence C4D crashes on the first keyframe of the time scale animation. I've tried with other renderers and had no problem.
A: Windows 10
B: 1080 Ti (x 2)
C: 64GB
D: 398.36
E: 3.08
F: 3.08.2-R2
G: C4D R18.057
Realflow for C4D time scale motion blur crash
C. RAM Capacity (i.e. 6 GB)
- automatik_vfx
- Attachments
- _BugReport.txt
- (455.23 KiB) Downloaded 227 times
- rf_emitter_03_retime.zip
- (113.37 KiB) Downloaded 230 times
Are you sure it's a octane problem? I see it's crashing at realflow.dll not Octane.
- automatik_vfx
Hi Aoktar,
Thanks for replying.
I have tried rendering the same scene with Arnold and Redshift and it works fine.
And I also tried exporting an alembic and rendering it from a fresh new scene and I get the same error, exactly when the time scale animation starts.
I if switch off motion blur from the camera tag and use guids is on it works but I won't get motion blur from other elements in the scene that are moving.
Hope this helps!
Hector
Hope this helps!
Hector
