Octane not rendering Tilt brush Data in Unity
Moderator: ChrisHekman
sunbyte
hello guys, wondering if anyone has a solution for using Octane on scenes that have Tilt Brush Elements ( with texture animation shaders etc).
let me know if you do, much appreciated.
_m
azen
Hello sunbyte,
To answer your question - we only directly support Standard, and Standard (Specular Setup) shaders. Aside from this, we also have a custom Shader called Octane/PBR Override. This provides you with a means to create a custom material using the OctaneRender Nodegraph Material Editor. There is a lot of flexibility in this editor, and it should be possible to create whatever you are seeking to achieve right here.
Hopefully this puts you on the right track. Let us know if you have any other questions.
Azen
Return to “Unity”
