v3.08.09 issue named GPU Failure
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
finkaboutit
I have big issues with the new stable version (3.08.09). it is crashing with a scene working well in 3.07.
Dialog box tell me there is a gpu Failure and stop the render. I don't understand why.
my driver version is the latest 398.11. i tried to unactive card by card ( i have only two one )..nothing is working..
Thx to help me !.
Here is the octane log:
Started logging on 26.06.18 11:43:08
OctaneRender 3.08.1 (3080100)
CUDA error 2 on device 0: out of memory
-> failed to create context for pinned memory
device 0: failed to pin film buffer
CUDA error 999 on device 0: unknown error
-> failed to deallocate device array
-> could not get memory info
-> failed to deallocate device memory
-> failed to deallocate pinned memory
-> failed to unload module
CUDA error 999 on device 1: unknown error
Failed to free page-locked memory
paride4331
Hi finkaboutit,
you could try with Nvidia drivers 388.13, or 391.35.
To get an effective Nvidia drivers installed, you could use DDU Nvidia unistaller drivers, the best way to get a clean installation.
http://www.guru3d.com/files-details/dis ... nload.html
Are you using Windows 10? Did you do Windows 10 Fall Creators Update before reporting Nvidia issue?
Regards
Paride
finkaboutit
Hi paride and thanks for your answer.
I'm running under creators update. windows 10 pro build 1703.
Have i to reinstall and staying under build 1603 ?
If i have to do that, i will install the driver version you advise after reinstalling, if not i will use ddu and reinstall the good driver version.
I stay tuned.
Thanks to you.
paride4331
Hi finkaboutit,
some users report issue after upgrade, you could try the Nvidia drivers before windows recover.
Regards
Paride
finkaboutit
I have to launch renders now so i can't try today, but i tell you when i reinstall the driver ;).
Thanks another time Paride.
paride4331
Hi finkaboutit,
Let me hear from you,
Regards
Paride
finkaboutit
Thanks Paride ! It is working ! you rock man !
fucking nvidia driver version !
It would be really helpful to create a forum section with good versions of nvidia drivers or advise them into the releases posts.
Thanks a lot ;)
Return to “Bug Reports”
