Help with Understanding Displacement
RSgraphics
Hey everyone.
I have a project due Monday. Very simple scene (download attached). Its a parametric cube and I'm having the following issues:
1. Once I bevel the edges, the displacement map separates at the edges. I understand this is because I'm breaking the UV's once I bevel and tried using box mode but that just makes every side of the box have the displacement instead of just the front face. I've tried making the object editable and selecting just the front polygons but i still get the funky edges.
I'm hoping someone can download the scene and fix the Displacement to only show on one side and to have nice edges and also explain if my work flow is incorrect.. I uploaded my file and screen shots to help.
Thank you,
Robert.
OTOY HELP.zip
File for Review
(80.21 MiB) Downloaded 261 times
RSgraphics
Here are the screen shots
jayroth
Displacements in Octane can be a little tricky at times. In this case, the parametric cube is part of the problem, as the face vertexes of the cube are NOT welded together. You will need to convert your cube to an editable object, and optimize your points. This will weld the cube into a single cohesive object, which Octane will have better luck displacing. That said, there are still potential issues, to my recollection. You might need to adjust the displacement midpoint option to either 0 or 1 (defaults to 0.5). That should get you mostly there, but you may still have trouble. Searching the Cinema forums for displacement will get you more information.
Good luck!
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
niestudio
try changing this displacement dropdown to follow geometric normal.
It closes the gaps here
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
RSgraphics
jayroth wrote:Displacements in Octane can be a little tricky at times. In this case, the parametric cube is part of the problem, as the face vertexes of the cube are NOT welded together. You will need to convert your cube to an editable object, and optimize your points. This will weld the cube into a single cohesive object, which Octane will have better luck displacing. That said, there are still potential issues, to my recollection. You might need to adjust the displacement midpoint option to either 0 or 1 (defaults to 0.5). That should get you mostly there, but you may still have trouble. Searching the Cinema forums for displacement will get you more information.
Good luck!
Yeah I tried all the usual settings. But this is beyond that. I tried with and without parametric objects and both had similar issues. The C4D cube is auto welded together by C4D. However a cylinder wont be auto welded as you described.
RSgraphics
niestudio wrote:try changing this displacement dropdown to follow geometric normal.
Niestudio, which version are you running? Im using C4DR16 and octane 3.08. My version doesnt have that menu selection.
niestudio
I'm on 3.08 too, but R17. Not sure if there's a difference from R16 to R17.
Can you post a screenshot of your displacement tab?
RSgraphics
Here you go
niestudio
Perhaps you have an older release of 3.08
RSgraphics
Oh i see. Its 3.06.
Im a little hesitent to upgrade. Dang maybe i should go for it.
