Model polygons visible in the render?
FIGAROCMS2018
Hello,
I downloaded a free model off of cgtrader, and here's what it looks like in C4D:
https://i.imgur.com/Z8ubquS.jpg
The problem is, - as you can see - that the polygons are showing in the render. How do I get rid of that? Do I have to blend polygons with eachother manually? Or is there a special setting to get rid of this effect?
FYI : the end goal isn't to retexture the object, I just want to have it one solid color. But without seeing the polygons!
Thank you.
check the c4d Phong tag, and convert the materials to Octane materials.
ciao Beppe
FIGAROCMS2018
Hello bepe, thank you for your answer. However, even with a phong tag (I tried many combinations), and with an octane material, I can still see the polys.
Here is a picture :
https://i.imgur.com/h7KxJQI.jpg
Here is a link to the .obj file I'm having trouble with.
https://drive.google.com/open?id=1gTOUp ... iw8CQYeCJ9
Do you have another idea of what I could troubleshoot? Thanks
frankmci
FIGAROCMS2018 wrote:Hello bepe, thank you for your answer. However, even with a phong tag (I tried many combinations), and with an octane material, I can still see the polys.
Here is a picture :
A little poking around seems to say there's a problem with the vertex vs. face normals of the model, where the two don't agree. Unfortunately C4D's normals tools aren't the most powerful, so the only way I could fix the problem within C4D was to Triangulate the model, forcing a full normals re-build. I generally avoid modeling in C4D, though, so there may be better way.
If you've got another tool, like Maya or Blender, they should be able to fix it without adding geometry. In Maya, try selecting all faces, unlocking normals and using Set To Face. In Blender, the "recalculate normals" tool should do the same thing.
- Frank
