Easiest way to increase or lower a bump map?
animas3D
Greetings everyone.
I am using a noise node to drive the bump map of an Octane material.
In the bump channel, there doesn't seem to be a value for the amount of the bump effect.
What is the most common way to control this?
Thank you.
Joe.
you can use a color correction node between the noise, and the Bump pin, and play with Power, Gamma, Contrast, to get the effect you want.
ciao Beppe
Studio21
multiply with a float texture
