OctaneRender™ for Blender 4.0 XB3 - 16.0 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows version only, as this is only an experimental build.
This is a TEST version, so be prepared to have some issues. Do not use it for production.
  • Upgrade to V4 XB3
  • Support new features in v4
  • Merge all changes up to 15.2.4
FIXES SINCE LAST RELEASE
  • Fix crash issue with large mesh
  • Fix empty feedback issue when denoising
  • Merge all fixes up to 15.2.4
You can read about new features of OctaneRender™ 4.0 XB3 here:
viewtopic.php?f=33&t=67790
1. OctaneRender™ Server
Windows
Blender Octane Edition - 16.0 (2.79)
Octane Server - 16.0
DrawFun
Please note that this release is based on Octane V4 XB3, we recommend that you mention that it is experimental, they should not use it for production work, and that we cannot guarantee backward compatibility.
A bit more detailed update logs for v4:
- Added AI Denoiser settings in Camera Imager Panel for interactive mode, and in Octane camera object, in the Imager section.
- Added denoise passes in Render Passes Panel
Important Hint: Please ensure the denoise is enabled before rendering denoise passes.
Thank you.
