Network render Cinema 4D slave problems
rokklancnik
I have problems with setting up the deamon on slave machine. I followed instructions and installed daemon, the I run it and there is my problem. Before net render slave launches I got an error (in cmd) "failed to connect to load COM data 5". Then it launches but there is no communicatio between master and slave. Is there any requirements for both PCs how they should be connected? Now, each is connected to a switch, sharing everyting, they see each other and can transfer files, ...
Any ideas what could be wrong?
Rok
please, uninstall the current installed daemon, and update both Master and Slaves to 3.08.1:
viewtopic.php?f=24&t=67352
Also be careful to have not bitdefender active while installing the daemons.
ciao Beppe
