OctaneRender™ for Blender 3.08 - 15.2.4 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions.
  • Upgrade SDK to 3.08.1
  • Support environment texture backward compatibility
  • Support enum options backward compatibility
  • Bring back the preview camera imager settings(“3D View”-“Octane Camera Imager(Preview Mode)”)
  • Provide an override option to use preview camera imager in all cases
  • Optimize updates of environment texture
FIXES SINCE LAST RELEASE
  • Fix version number verification failure in some platforms
  • Fix livedb specular material crash
  • Fix some compilation optimization failures based on render layer and visibility
  • Fix a crash in external openvdb
  • Fix preview render failure in scenes without cameras
  • Try to fix crash when rendering with unsaved file under osx
You can read about new features of OctaneRender™ 3.08 here:
viewtopic.php?f=33&t=63219
1. OctaneRender™ Server
Windows
Blender Octane Edition - 15.2.4 (2.79)
Octane Server - 15.2.4
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v15.2.4 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.2.4 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.2.4 OSX ZIP
