When I try to install Octane in the latest Unity (on a new project) this error happens:
Failed add install extension to unity: 1
UnityEngine.Debug:LogErrorFormat(String, Object[])
OctaneUnity.ExtensionInstaller:InstallExtension()
OctaneUnity.InstallChecker:UpdateOnce()
UnityEditor.EditorApplication:Internal_CallUpdateFunctions()
When I restart Unity this error happens twice. After two times asking me to install Octane.
Is Octane working with Unity 2018.1.4f1?
Moderator: ChrisHekman
- ChrisHekman
This attempts to install the installer toolbar extension, but that appears to be blocked from being installed.
You dont need it to use the OctaneForUnity, and you should be able to skip it.
I skipped (twice). No errors.
The Octane menu only shows "Settings".
Then I try to "Load Octane", and...
EntryPointNotFoundException: LoadLibrary
Octane.DynamicLibrary.Load ()
Octane.PluginDllLoader.LoadLibraries ()
OctaneUnity.PluginController.Init ()
OctaneUnity.PreferenceWindow.OnGUI ()
System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MonoMethod.cs:222)
Rethrow as TargetInvocationException: Exception has been thrown by the target of an invocation.
System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MonoMethod.cs:232)
System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MethodBase.cs:115)
UnityEditor.HostView.Invoke (System.String methodName, System.Object obj) (at /Users/builduser/buildslave/unity/build/Editor/Mono/HostView.cs:291)
UnityEditor.HostView.Invoke (System.String methodName) (at /Users/builduser/buildslave/unity/build/Editor/Mono/HostView.cs:284)
UnityEditor.HostView.InvokeOnGUI (Rect onGUIPosition) (at /Users/builduser/buildslave/unity/build/Editor/Mono/HostView.cs:251)
It does skip the installation procedure, but it gives another error.
When I try to "Load Octane":
OctaneUnity.LicenseManager+<>c.<GetTierDataFromServer>b__29_0 (AuthCodeResponse response)
UnityEditor.Connect.UnityOAuth+<GetAuthorizationCodeAsync>c__AnonStorey0.<>m__0 (UnityEditor.AsyncHTTPClient c) (at /Users/builduser/buildslave/unity/build/Editor/Mono/UnityConnect/UnityConnect.cs:92)
UnityEditor.AsyncHTTPClient.Done (State status, Int32 i_ResponseCode) (at /Users/builduser/buildslave/unity/build/Editor/Mono/AsyncHTTPClient.cs:201)
I'm using a macOS Sierra
