CUDA error 2
chreff
Hello, what's wrong? what could be the problem?
1080ti + 780ti
log
CUDA error 2 on device 0: out of memory
-> failed to bind device to current thread
device 0: failed to initialize context
CUDA error 201 on device 0: invalid device context
-> failed to create link
device 0: failed to create OSL compile context:
device 0: failed to compile module 0
ossdesign
Exact same setup (1080ti + 780ti) and same problem, when updating to latest Nvidia Driver. (398.11)
Worked while on 390-something. Trying to roll back.
But rolling back can' t be a permanent solution?
Did you figure out a fix?
"device 0: failed to compile module 0
device 0: failed to compile module 0"
Micha3D
Is the problem solved? I have seen errors like this at Rhino too and I ask me, could it be a driver problem too.
Win7 64 | Dual Xeon E5-2687W | GTX 1080ti 11GB + GTX 780 6GB | Rhino3D
try to use DDU to completely remove the previously installed drivers:
http://www.guru3d.com/files-details/dis ... nload.html
then perform a clean installation installation of 391.35 drivers for your operating system.
ciao Beppe
