OctaneRender™ for Blender 3.08 - 15.2.3 [OBSOLETE]
azen
OctaneRender™ for Blender plugin. Windows, Linux and OSX versions.
  • Upgrade to 3.08 stable
  • Upgrade to blender 2.79b
  • Support "Shift + Left Mouse” to select material directly
    • Firstly, use “Right Mouse” to select target object
    • Then, use "Shift + Left Mouse” to select target material
  • Support motion blur for reshapable objects
  • Use the same options as Octane Standalone for motion blur setting
  • Introduce enum properties to replace raw int sockets for octane enum pins
    • Much more understandable and user-friendly
    • Toon Light
    • BRDF Model
    • Metallic IOR Mode
    • Noise Type
    • Projection Mode
    • Rotation Mode
    • Interpolation Type
  • Support external vdb sequence(“Data – Volume properties”)
    • Similar to Lightwave implementation, we leverage special string tag(“$F$”) to identify frame parts in vdb path
    • Use “$F$” to label the frame parts in vdb file path - E.g. "fog_$F$.vdb" => "fog_0.vdb", "fog_1.vdb" ... "fog_10.vdb" … "fog_100.vdb"
    • Use “$[1-9]F”to deal with the leading zeros in file path - E.g. "fog_$4F$.vdb" => "fog_0000.vdb", "fog_0001.vdb" ... "fog_0010.vdb" … "fog_0100.vdb"
  • Support new layout in texture node menu
    • In default, the texture nodes are distributed in three categories: proceduals, tools, textures
    • Use new layout in default
    • Able to change new/old layout(“User Preference” – “Add-ons” – “OctaneRender Engine” – “Preferences” – “Texture Node Menu Layout”)
  • Support “Octane Layout” for textures as it is in 3.08 StandAlone
  • Support compilation optimization for objects/shaders that are invisible in current render layer
  • Support external openvdb import(“Data”-“Volume properties”-“Used as Octane VDB”/”OpenVDB File”)
  • Support to toggle octane node graph(“Render - Render - Show Octane NodeGraph”)
  • Support octane network preference setting(“Render - Octane server – Network preference”)
  • Support to choose HDR bit depth type in image texture node
  • Added emmision texture menu in texture node graph(for emission pin in volume medium)
  • Set OpenVDB as default value in smoke cache format
FIXES SINCE LAST RELEASE
  • Fixed linux render hanging
  • Fixed crash in scene without cameras
  • Fixed render layer mode bug
  • Fixed octane camera visibility
  • Reverted cycle render layer hiding
  • Fix environment texture uplate failure after rename
  • Fix missing marker menu
  • Fix infinite plane issue
  • Fix warnings about write_customdata error
You can read about new features of OctaneRender™ 3.08 here:
viewtopic.php?f=33&t=63219
1. OctaneRender™ Server
Windows
Blender Octane Edition - 15.2.3 (2.79b)
Octane Server - 15.2.3
Linux
Installation:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v15.2.3 Linux
OSX
Installation:
- Or, if you know what you are doing, you can use the ZIP archive to copy .app files manually.
DOWNLOAD
Autoinstaller: Blender Octane Edition - v15.2.3 OSX Autoinstaller
ZIP archive: Blender Octane Edition - v15.2.3 OSX ZIP
