3.08 Issues
Allan_onderick
I'm not sure if I'm posting this in the right spot. If I am not sorry.
Issues with 3.08
Rendering in C4D 3.08 renders take x3 longer then when using 3.07
Then after a Day of trouble shooting "CUDA error 719" Updating video drivers and system. And even uninstalling and reinstalling and getting 3.08 redering without errors still had extended rendering time issues.
Uninstalled 3.08 and went back to 3.07
A frame set in both 3.07 and 3.08
Pathracing
Max samples 1800
SD:12
GD:8
DD:8
AO Distance:4.2
Adaptive sampling: Min samples 256
Exposure:1
Gamma: 2.2
Response: Linear
Natural Responce
With current hardware setup:
3.07 1:45 a frame
3.08 6.32 a frame
I'll except the fact i might be doing some optimization wrong. But nothing that would make my renders take x3-x5 longer to render. And to be honest. I have never really had an issue like this with Octane. And I have don't have time to sit around poking around getting something to work that has always worked before. I need this to work. I don't need to work on it.
Windows Rig: Win 10 64, 64gb , 256 SSD, Stable OC i7 4.7Ghz Corsair water cooled, 1200 watt PSU, 3x MSI Seahawk GeForce GTX 1070 / amfeltec cluster x4 MSI Geforce 1080 Ti
Did you sent your scene to let be tested on somebody else? I haven't notified or reported somethings like that. A speed loss in a factor of %300-400, even not in %10.
Did you compared the versions on your system with different scenes?
Hi Allan,
please, share with me via PM a complete scene with assets that is goving you issues, to better investigate the problem.
ciao Beppe
Allan_onderick
Gentlemen,
I will load a file shortly.
