Many errors when using liveDB
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
dafassi
This error happens with the last test versions based on Blender 2.79.
1) Whenever you try to load specular-materials (try water) you wont see anything.
It seems there are some issues while importing all data from the liveDB.
2) Using the lifeDB needs some minutes to go. "Server is refreshing liveDB" is the message and appears with every start of BlenderOctane. The refreshing process sometimes needs >10 minutes! Frustrating.
3) Using your last build 15.1 is not possible as it crashs and crashs. Just tryed to add a new specular-shader to a mesh -> crashs! (Sometimes it works).
a. Win10 64bit
b. 1080ti
c. 32GB
d. 3.13.1.30
f. last testbuilds based on 2.79
Greets,
dafassi
WIN7 64bit • 32GB DDR5 RAM • Intel i7 6x4GHz • GeForce GTX780 • Blender
DrawFun
Hi dafassi,
Thanks for your report and sorry for the inconvenience.
I've reproduced the crash and the investigation is under way.
DrawFun
pegot
I just ran into this issue as well yesterday. Liquid materials downloaded from DB didn't seem to be rendering but if I made my own specular material it worked.
Win 11 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
DrawFun
Sorry for the inconvenience.
The crash issue will be fixed in the next release.
DrawFun
Return to “Bug Reports”
